Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. It sounds to me like the vernier is not being set to fast mode correctly my the PIC. and it is mis-reading the vernier as a binary version rather than a BCD type.
    Fire up a serial comms package or hyperterminal, if ALL else fails :)
    Set baud to 115,200, 8, n,1
    Send 'i0' and the PIC (in position X) should respond with something.
    ;command line interpretor
    ;Commands: (case insensitive)
    ;rx - Read - reads and transmits abs position (x=x,y,z,w)
    ;sn - Sets sample rate (n=0,1,2) 0 =poll mode, 1 = 300mS (normal), 2 = 20mS (fast mode)
    ;zx - zero vernier display (x=x,y,z,w)
    ;vn - set vernier type (n=0,1) 0 = old, 1=decimal
    send V1 to set decimal vernier, then S0 to set poll mode, then RX and the pic should respond with X00.000: (inches) or X000.00:
    (mm). If it returns XH000000: then it is not reading the vernier as a decimal type.
    I have one vernier here that has a similar problem , so if I can fine the time I'll look into it. In the mean time, you could try inserting an extra pulse clk in the setfast routine
    Code:
    setFaut        bsf    Mode,Auto
    setFast        bsf    Mode,Fast
            clrwdt
            call    zeronorm
            clrwdt            ;pulse clk again if decimal type
            call    Dly200
            call    Plsdata
            btfss    Mode,Vtype
            return
            call    Dly200
            call    Plsclk
            call    Dly200   ;exta pulse clk *******
            call    Plsclk
            call    txZero        ;send zero message
            return
    A quick PIC to PC test:
    disconnect serial lead from PC , disconnect vernier from PIC
    Run VB application, select correct comm port
    Connect serial lead, connect vernier to PIC - you should see a new frame appear for X, Y, Z or W - if this happens the serial port is working OK.
    you should see the vernier be reset to zero then depending on type H (for hold) and F (for fast)
    Press ZERO (and hold) on the vernier, this will stop the clock signal, after a second or less the PIC will signal the PC to remove the frame .
    Releasing the zero will start the clock, the PIC will signal the PC and the PC will issue a reset to the Vernier.
    If all of the above works the serial comm must be working fine.
    Quote Originally Posted by BillTodd View Post
    Code:
    clrwdt
    call zeronorm
    call Dly200
    call Plsdata
    btfss Mode,Vtype
    return
    call Dly200
    call Plsclk
    call Plsclk
    return
    Thanks Bill,
    I'll try all that, its all very usefull info.
    As I say in the word attachment I also have another vernier I can try and that one has the abs and rel 24bit packet output format. I'll wire that in first to try, then I'll try to adjust the asm code as you suggest for the BCD version.
    What confuses me slightly is the need to run the vernier in fast mode. I thought this is just the update rate and should not cause corruption of the data. I know it is good to get the 40 updates per second for real use on the Mill or Lathe but for test purposes does it matter?
    Cheers,
    Code:
            clrwdt
            call    zeronorm
            call    Dly200
            call    Plsdata
            btfss    Mode,Vtype
            return
            call    Dly200
            call    Plsclk
            call    Plsclk
            return
    Bill, I have not tried the Hyperterminal test yet or tried adding another pulse to the code. I have not had time yet to try another vernier type either but i did try the simple comms port diagnostic test you describe. When you hold the zero button it stops the clock and the VB app clears the vernier off the display window, Y in my case. On releasing the zero button the Y display returns. The clock and data line LEDs to the vernier flash in a sequence, the vernier display zeroes but in general it leaves it in th H (hold) mode, never in the F.T Fast Read mode. Sometimes the clock and data pulsing sequence repeats a few times till it settles down to the Hold mode. Sometimes it leaves the vernier in the slow mode but this is rare.
    I must try and test the other Vernier I have and give an update before trying the other tests.
    Cheers.
    Quote Originally Posted by 1113562 View Post
    Cheers.
    Update: I Tried the other vernier which was very recently bought from Aldi but this just caused the PC VB6 App to go nuts with overflows and crash. This vernier is quite different from the older one I fist tried in that the interface pulsing on the clock and data lines at connection detect do not appear to change the setting modes at all on the vernier. Also when you push and hold the zero button on the vernier it just pulses the clock line for about 1/2 second it doesn't hold it off continuously while the button is depressed.
    I then tried using hyperterminal with the older BCD type vernier as per the diagnostics tests recommended but this was not good. When the vernier I/F is plugged into the PC COM1 port hyperternial complains it cant open the com port. I think I am correct in setting HT to 'no flow control'? I did try 'hardware control' mode but that suffered the same fate. I thought then that I did have a wiring problem either in my serial link cable or the I/F driver circuit but I checked both and they seem to be correct to drawing - strange.
    I'm not sure what to try next!!!
    Cheers - John
  5. What confuses me slightly is the need to run the vernier in fast mode. I thought this is just the update rate and should not cause corruption of the data.
    No it shouldn't, but if the PIC is not able to change mode correctly, it probably wont detect the vernier type (binary/bcd) either. If you use a comms program you should be able to force the PIC to use poll mode (read and report when asked) and binary/bcd type which should confirm the data splicing and clock detection is working properly.
    Does your vernier's data and clock signals look like (timing wise) those on the yadro site?
    http://www.yadro.de/digital-scale/protocol.html [edit- just had a look at your word doc, all looks ok there]
    I'm right in the middle of a job ATM, but I'll try to have a look at my errant vernier (looks and behaves very much like your one) at the weekend.
    OK Bill you have been more than helpfull on this problem there is no rush at all.
    As you have seen in the word doc the vernier I am trying looks very much like it is the same as the 7 BCD protocol as per the YA DRO site. According to that site to get to fast read needs a single data then a clock pulse from the PIC so this is where the difference may be as this vernier is not going straight to Fast Read mode.
    I'll try the othet Vernier I have at home this evening which is definitely the 2 packet 24 bit binary protocol and I'll see how that performs before fiddling with the PIC code.
    I was thinking it may be worth developing a simple emulator coded PIC just to put in the socket for testing the COMS from Interface to PC, i.e one that just generates known values and responds to abs zero controls etc. Putting two or more of these test PICs on the interface board could also be used to test the data splicing - just a thought and you may well have thought of this and rejected it for good reasons.
  7. Hi John,
    Ok I found some time this morning to look at my other verniers...
    There seems to have been an explosion of vernier types since I wrote the PIC code; I have half a dozen different verniers here with five different output formats! (including Mitotoyo, which is completely different) With your two that makes at least six 'chinese' formats. I have a one I bought in the USA with fractional inch display (very handy) that outputs fast 25mS pulses and, like your Aldi one, does not respond to clk or data switching.
    I think the best way forward, is to drop the automatic device detection from the PIC code and add some manual set up commands and a configuration page to the VB prog. (I want to add a DRO to my Haighton at sometime so it is something I will have to sort out).
    It would help, to know the switching sequences for your BCD one, so if you get the chance to work them out.... :)
    Bill
    Hi John,
    Bill
    OK Bill, I will do a controlled test of my BCD vernier to get the sequence and report back. I'll just code up a simple pulse generator in one of the PICs.
    I'm glad you mentioned that the mitutoyo verniers have a completely different protocol as I nearly bought a 24" one a few days ago on eBay. It was mainly for the bar/PCB but using the reader would also be good.
    btw. Good idea about having a manually selectable Vernier type in the VB app.
    Cheers, John
    Cheers, John
    OK I have done a test on the BCD vernier which is a Workzone 6" bought from Lidl or Aldi, can't remember which. I have attached an image of the state diagramClick image for larger version.
Name:	VBCD Vernier State Diag.jpg
    It starts always at power up in Slow Read mode. To get from switch on to Fast Read (F.T) needs a Data then a Clock Pulse. To Zero at power up on route to F.T then its Clock then Data then Clock. When in F.T. to Zero needs a Data then CLock then Data then Clock. There are other states as shown in the diagram that are of no interest to our use I suggest.
    John.
    John.
    This version of Vernier seems to be virtually the same state diagram as that on the YADRO site but they do not show some of the hold states.
  1. Website idea.
    By qwertyjon in forum General Computing
    Last Post: 05-04-2014, 03:29 PM
  2. Here's an idea hacking a Kress 1050 FME
    By m.marino in forum Kress Milling Motors
    Last Post: 16-01-2013, 01:05 AM
  3. Why they don't want to accept my idea?
    By hoezap in forum Tool & Tooling Technology
    Last Post: 14-07-2012, 01:15 AM
  4. business idea?
    By homer93 in forum Marketplace Discussion
    Last Post: 01-06-2012, 12:56 PM
  5. BUILD LOG: Mel's Odd Idea
    By mel_earp in forum DIY Router Build Logs
    Last Post: 19-03-2010, 11:54 AM
