Thread: Cheap Idea for a DRO
Update: I Tried the other vernier which was very recently bought from Aldi but this just caused the PC VB6 App to go nuts with overflows and crash. This vernier is quite different from the older one I fist tried in that the interface pulsing on the clock and data lines at connection detect do not appear to change the setting modes at all on the vernier. Also when you push and hold the zero button on the vernier it just pulses the clock line for about 1/2 second it doesn't hold it off continuously while the button is depressed.
I then tried using hyperterminal with the older BCD type vernier as per the diagnostics tests recommended but this was not good. When the vernier I/F is plugged into the PC COM1 port hyperternial complains it cant open the com port. I think I am correct in setting HT to 'no flow control'? I did try 'hardware control' mode but that suffered the same fate. I thought then that I did have a wiring problem either in my serial link cable or the I/F driver circuit but I checked both and they seem to be correct to drawing - strange.
I'm not sure what to try next!!!
Cheers - John
Website idea.
By qwertyjon in forum General ComputingReplies: 8Last Post: 05-04-2014, 03:29 PM -
Here's an idea hacking a Kress 1050 FME
By m.marino in forum Kress Milling MotorsReplies: 3Last Post: 16-01-2013, 01:05 AM -
Why they don't want to accept my idea?
By hoezap in forum Tool & Tooling TechnologyReplies: 5Last Post: 14-07-2012, 01:15 AM -
business idea?
By homer93 in forum Marketplace DiscussionReplies: 7Last Post: 01-06-2012, 12:56 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
