Thread: Physics Guru needed
Could any of you Maths or Physics wizards tell me how much deflection I could expect on two sections of 25mm precision rail supported at both ends by 50mm with 500mm between supports with a carriage of (L)200mm X (W)300mm (4 bearings) fitted. The mass on the carriage is approx. 25Kg? Oh and please keep it simple if possible.:confused:
Thanks in advanceTim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
07-05-2010 #2
yes I can tell you...
oh you mean like now?
when I get home.... sometime this weekend
07-05-2010 #3
07-05-2010 #4
Since I've just had my structural analysis exam today I had vowed not to do any more calcs for at least a week........:nope:
So use this site http://www.engineeringtoolbox.com/be...on-d_1312.html
use the metric option Beam Supported at Both Ends, Load at Center
q= load = mass x gravity (25kg x 9.81= 245.25N) add the weight of the carrige as well
l = length in mm
I= moment of inertia = pi times r^4/4 = 19174.76 mm^4 (for a circle)
E= modulus of elasticity (find out from supplieror or use 200000 N/mm^2 for steel )
y= radius (25mm)12.5mm (thanks Irving)
This is only for a simply supported beam so will be worst case, If the supports are nice and solid then you could go for a fixed beam. I'll have to digg out the formulas and do an excel sheet for all the options.
I think most of this is correct, my brain is pretty fried at the mo tho:heehee:
Good luckLast edited by Ross77; 08-05-2010 at 12:19 AM.
The Following 2 Users Say Thank You to Ross77 For This Useful Post:
07-05-2010 #5
07-05-2010 #6
huh, beat me to it...
deflection of a fixed-fixed beam with a central point load (worst case) is:
d = P (l^3)/(192 E I) = 250 (500^3)/(192 * 2e5 * pi/4 * 12.5^4) = .042mm
Ross - sanity check - radius is 12.5 not 25 - they were 25mm beams.
08-05-2010 #7Ross - sanity check - radius is 12.5 not 25 - they were 25mm beams.
I just spent 3 weeks revising, slope defection by equation and integration, stress and strain, and dynamics:- centripetal force, Dynamic amplification factor, Euler rule etc etc. and the question was how to calculate the Natural freq.........F**kin typical
told you my brain was fried.......
ok so r= 12.5didn't you read the caveat
( see first paragraph)
Lee ,Sure I will sort something out for you. But better get Irving to check it eh......
09-05-2010 #8
Yea sure make it collaboration if you like, maybe even put it into a .exe and keep it going as a MYCNCUK work in progress program, then you could add things to it as you come up with them, like Irving’s motor calc sheet. Would be cool, I think we may need a "MYCNCUK Browser Toolbar as well what you think?, I was looking at making a taskbar app as well for the site, you could install it and it would inform you of new PM’s and reply’s and so on.
The cals will be pretty easy to do as there are only the 3 beam types, cantilever, simply suporrted and fixed. the trick will be explaining how to use each one and the conditions required to meet them as i'm sure some of the bar mounts sold couldnt be classed as fixed.......
I'll do a draft and Pm it to you and Irving(if he's interested that is)
What happened to the motor calc sheet? i thought you hade a tutorial section but I cant find it anywhere. Browser tool bar sound good if it makes finding things easier.
P.S what with all this 'serving the masses'??? have you got a summer job at Burger King?:heehee:
11-05-2010 #10
You need to decide whether your end supports are rigid enough to justify treating the rail as 'encastre'. By this I mean are they strong enough to resist the rotation of the end of the rail when it is loaded. I suspect that it would be fairer to treat the ends of the rail as being simply supported. In which case, the deflection is given by P(L^3)/48EI This will give a deflection four times greater than Irving's.
I would treat Irving's solution as the best possible case and mine as the worst possible case. The true answer would lie somewhere inbetween.
1 3/16"-16 tap and die needed
By dazza in forum Marketplace DiscussionReplies: 4Last Post: 26-12-2013, 05:36 PM -
help needed going to the next level
By luke11cnc in forum Computer SoftwareReplies: 8Last Post: 20-09-2012, 08:53 AM -
help needed for .drg files
By swinds in forum Machine DiscussionReplies: 0Last Post: 22-06-2011, 09:18 PM -
WANTED: Needed for my build
By jpcnc in forum Items WantedReplies: 9Last Post: 08-01-2011, 02:22 PM -
Advive needed.
By Kammo1 in forum Stepper & Servo MotorsReplies: 4Last Post: 02-06-2010, 10:29 PM
