    Hi John..
    Have them wired in series and running at 2.5 amp.. Thats the way to get the most torque out of them yes? Have them stepping at 1/16th as the chain is a course pitch (1/2" pitch with 9 tooth drive spocket).. Tried them at 1/8th step but same problem..
    Have the boards just out in the open at the moment, will put them in a nice box when everything is working.. As it was so cold in my workshop the last few days I did not think it would be a problem, but do you think they could be over heating? If that is a possibility I will box them with a nice fan before my next hair pulling session..
    I was kinda thinking it might have been something in Mach 3 but the probs are a bit variable..
    Steve..
    Steve, check your pulse setting in Mach.
    go config > Motor Tuning and check the step pulse rate, try 5 or even up to 7
    Gives it a longer pulse so the driver has chance to see it.
    It's a funny setting as it's computer related, even if you are given an XML with it set at 5 your computer may see it at any figure, usually far lower than needed.
    John S -
    Had similar problem on my machine when trying to run the motors too fast, they would work for a few minutes then started locking up and losing steps.
    I did what John has suggested to you and put a bloody big fan cooling the driver cards (2 in fact), never had a problem since. Other than that you could try slowing the steppers down a bit.
Name:	Driver cooling 1.jpg
  1. x-axis on Orac losing direction
    By asto in forum Motor Drivers & Controllers
    Last Post: 29-03-2013, 01:22 AM
  2. Help! Steppers losing steps and making a racket under slow feed..
    By fasteddy in forum Stepper & Servo Motors
    Last Post: 06-08-2011, 03:03 PM
  3. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
  4. z axis loosing steps
    By ptjw7uk in forum Machine Discussion
    Last Post: 10-05-2010, 07:38 PM
  5. dual drive x-axis?
    By fasteddy in forum Linear & Rotary Motion
    Last Post: 13-06-2009, 11:05 PM
