Thread: ello
I have a 1100 sq ft workshop so space is not a problem. I was thinking floor mounted so it can be setup in a corner and not be moved. I think i agree with you on the PCB so i might have to look into converting an epson printer to printer directly onto the board instead of using the press 'n' peel lazer printer method im using atm.
Thanks for the info Irving i will have a read.
1 more queston does Maplins do any kits for CNC that you know of?
Ello!
By oscar in forum New Member IntroductionsReplies: 1Last Post: 25-10-2012, 09:08 PM -
NEW MEMBER: Ello from Hull
By Kai in forum New Member IntroductionsReplies: 1Last Post: 31-10-2010, 06:40 PM -
NEW MEMBER: 'Ello.
By korky in forum New Member IntroductionsReplies: 7Last Post: 14-05-2009, 11:41 PM
