AH, I was confused by the statement
many people use the term backlash when they mean endfloat and i thought the nut you refered to was holding thr handle in place...The handle for the Y axis (before I removed it) did seem a little harder to turn than the X-axis so I may try loosening the nut. I tightened it to reduce the backlash
27-05-2010 #2
I've had some luck with the Y axis now. I loosened the gib strip which helped a bit however it strikes me as being too loose now. I adjusted the backlash adjustment and now I've got 2300mm/min on the Y axis, but about 0.2mm of backlash instead of 0.065mm.
Good news with the Z, 4600mm/min with 1:1 pulley!!!! It will do more if I change the motor to half stepping because the computer is limiting the pulse rate I can use at 1/4 microstep, however 4600 is plenty fast enough for an axis that's only got 92mm travel. I'll keep it at this ratio to preserve torque for drilling etc
So to summarise:
X, 2520
Y, 2300
Z, 4600
Overall I'm very happy with this - can't wait to start machining things again! Thanks for all the help that's enabled me to do this...
Also, could someone point me to a simple program to import a 2D .dxf and generate g code for '2.5D' milling from it?
28-05-2010 #3
Try cambam, theres a free version and a pay version http://www.cambam.co.uk/
Matching Drivers with Steppers
By hoppo in forum Motor Drivers & ControllersReplies: 4Last Post: 21-11-2012, 01:19 PM -
Any one used drivers and steppers from CNC4you
By sebring115 in forum Motor Drivers & ControllersReplies: 14Last Post: 30-11-2011, 11:32 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM -
Has anyone used these steppers or drivers?
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM -
Steppers and drivers
By Davidh in forum Motor Drivers & ControllersReplies: 3Last Post: 12-06-2009, 05:59 PM
