  1. Are you proposing fixed gantry/moving table or a moving gantry? If the expected workpiece is relatively lightweight (small amount of MDF, balsa wood, PCBs, etc.) I'd suggest a moving table design gives more bang for the buck so to speak. A moving gantry is going to be quite a lot heavier, harder to make rigid and will limit the performance with a small motor.
    I concur on the 12x3 trapezoidal. Its not so expensive and even without an antibacklash nut will give a better result than M12 rod.
    What about the spindle? Dremmel or something meatier?
    Oh and on the stepper drivers, came across these... no idea how good or what chip, was thinking about getting one to find out but at £8.99/channel.... They also do a cheap (£30) 27v/13A PSU
    I was thinking of going for a moving table as like you say it will give more bang for buck and the design should end up simpler which is what we are aiming for.
    Spindle - will probably go with a dremel to start with as I happen to have a couple kicking around and they should suit what we will be cutting, there are plenty of dremel's on ebay and also copies for not a lot of money so it makes sense to go down that road. I will design it with the option to put something meatier on there but I really don't think it will be suitable for an entry level type machine but then again you never know!
    Just checked out those stepper drivers and they don't look too bad, especially for £8.99. Has anyone ever had a go with one of these before?
    Thinking about the trapezoidal again, just changed my mind and now going for M10 x 2mm. A little bit cheaper and no micro-stepping drivers needed.
    1 stepper motor rev = 200 steps @ 2mm pitch means 1 step = 0.01mm - I know you can state whatever steps per unit you want to in mach3 but this way it will keep it simpler for the beginners...
    Starting to talk in numbers and equations like Irving now!
  1. Results from my home-built parts tumbler...
    By Wal in forum Metal Finishing Techniques
    Last Post: 07-07-2014, 02:29 PM
  2. NEW MEMBER: CNC Router Parts
    By CRP in forum New Member Introductions
    Last Post: 29-10-2013, 02:37 AM
  3. 3040 size router plans?
    By m_c in forum Gantry/Router Machines & Building
    Last Post: 24-06-2012, 04:15 PM
  4. Trying to find a kit or plans to build.
    By don_jarr in forum Gantry/Router Machines & Building
    Last Post: 16-06-2011, 04:28 PM
  5. NEW MEMBER: Hi from rainy York - build plans/questions
    By bikepete in forum New Member Introductions
    Last Post: 11-10-2009, 07:43 AM
