Thread: stepper motors glitching
10-06-2010 #23
Is the glitching at the same frequency? Is there one speed where its worse? I wonder if you're experiencing mid-band resonance where the mechanical and electrical parameters combine to absorb energy to the point where the motor cannot maintain enough torque and therefore loses steps. If you sweep the frequency can you determine a specific point where the glitching is worst? If so, try adding some damping to the motor shaft, e.g. a flywheel or some other angular weighting. Does it still glitch then and has the glitch point moved? If so this would indicate a resonance issue.
Stepper motors - problem
By dudz in forum Stepper & Servo MotorsReplies: 7Last Post: 13-02-2013, 07:07 PM -
stepper motors not being driven
By sprint in forum Machine Control SoftwareReplies: 4Last Post: 12-02-2013, 03:42 AM -
Help with Stepper Motors
By Scott in forum Stepper & Servo MotorsReplies: 8Last Post: 04-04-2010, 02:35 PM -
rs stepper motors
By chaz@2b in forum Stepper & Servo MotorsReplies: 19Last Post: 06-08-2009, 11:05 PM
