Thread: help please with first attempt
Ok, the data sheet for those motors is here (the S is single shaft, B = double shaft)
With those motors & driver you have the option to run them wired bipolar series at 2A or bipolar parallel at 2.5A (which is the limit of the driver, not the motor)
To run them in bipolar series, you need to join blue to red/white, use blue/white = 1A, red = 1B, join green to black/white, use green/white = 2A, black = 2B
To run bipolar 1A = Red+Blue, 1B = red/white + blue/white, 2A = green + black, 2B = green/white + black/white
31-05-2010 #2
Thanks for the link, Have now tried changing wires to both ways still no motor output, now looking at System 4 pcb, have blue power led on all time, have a green power save led on all time, 2 red signal led's fade out under 60 sec, 4 yellow direction XYZA led's never seen on.
all port pins set as per sys4 book, power is 28vdc, mach3 settings all appear to be correct, am I missing something out should anything else be enabled? can sys4 board be checked out/tested?
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
ok, first attempt using sketchup 8
By deannos in forum Gantry/Router Machines & BuildingReplies: 89Last Post: 25-08-2012, 03:00 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
