Thread: mach3 mill
  1. #9
    jo200's Avatar
    Location unknown. jo200 Last Activity: Has a total post count of n/a. Referred 6797 members to the community.
    Thank you for your reply. I had another half hour this morning and made some dial measurements. The back lash in the new H screw is 0.08mm and in the Y screw 0.05mm.
    In order to finish the miller off, I need a plate to mount the Z drive and this plate has a hole of 32 mm . So I thought I would use the Hole Wizard. Having set units to mm and entered the data for X and Y centres plus hole diamter, I did a test run.
    No good, circle was far too big-- recheck data still too big. Change diamter data and re-run but the same size appears. The X and Y centres are spot on, the no mater what diameter I enter into the wizard (and save) the G code always describes the big circle. I realise that the wizards are not supported, so need to ask if there is a known problem? or is it me?. many thanks // Joe
    Ohms law states that the current through a conductor between two points is directly proportional to the potential difference (PD) or voltage across the two points, and inversely proportional to the resistance between them .
Name:	ohms law wheel.jpg
  1. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  3. eBay: Denford Triac CNC milling machine mill mach3
    By Fivetide in forum Items On eBay UK
    Last Post: 19-11-2012, 01:46 PM
