Thread: Making a Jig
    Hi Folks,
    I have attached a sketch of a Jig I would like knocked together, I can arrange for the required materials to be delivered to you along with payment and return postage.
    How it is made and what of, is up to you, although as I will be running a drill through the holes maybe steel rather than aluminium would be a better choice. I also leave up to you the method of attaching the sides to the top plate.
    It's use ... to accurately position holes in 45mm Extrusion as (for now at least) I do not have access to a Pillar Drill.
    If you can see any glaring errors in the drawing or have a better method of doing it please shout!!
    Many Thanks
    Tim
    Tim G-C
    “I disapprove of what you say, but I will defend to the death your right to say it.”
    (attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
    Just a quick question, Is the extrusion a hollow tube.
    If so and the holes have to be in line then your jig will not be all that good if the holes are to be made with a hand drill.
    The part the drill goes through should be a lot longer about 25mm, that is if the holes have to be in line accross the extrusion.
    Peter
    You only need one side and a top, a clamp will locate it and stop it moving.
    As Peter says you need a greater depth to the top part or fit hardened drill bushings.
    Seriously look at getting a drill, they are indispensable.
    By the time you have paid postage two ways and got someone to do this you are probably half way towards getting a S/H one.
    John S -
    Point taken Gentlemen ... Off to find a pillar drill next week ...
    Tim G-C
  1. Making a little box
    By mark84 in forum General Discussion
    Last Post: 11-03-2014, 11:34 PM
  2. Making the frame square
    By cropwell in forum Gantry/Router Machines & Building
    Last Post: 08-03-2014, 11:00 PM
  3. RFQ: aluminium mold making
    By kell in forum Projects, Jobs & Requests
    Last Post: 24-03-2013, 01:40 PM
  4. Mold Making?
    By Shinobiwan in forum Moulding Machines
    Last Post: 27-02-2013, 02:15 AM
  5. Anyone making fitted kitchens?
    By Chas in forum Woodwork Discussion
    Last Post: 31-01-2013, 05:29 PM
