    Thanks for that. By "springing" 2 nuts together, is that as obvious as it sounds? I've got visions of 2 nuts on the threaded bar in opposite directions and a spring between the 2 pushing them away from each other. Or is "springing" a technical term for something completely different?
    TIA
    Paul
    Quote Originally Posted by pjl83 View Post
    Hi Paul
    Put two ball nuts close together on the same screw, arrange it so neither can turn but one can slide. Add springs to push them together or apart.
    I use Belleville washers and preload them to about a quarter of a ton, so I get zero backlash up to that point.
    Obviously this won't work with ordinary nuts, they'd just seize, has to be a rolling contact.
    I also spring the thrust races holding the ball screws in place. It's complicated to do but solid as a rock
    Robin
ID:	2260   Click image for larger version.
    Thanks.
    So let's just say that I was going to use threaded bar I know it's not ideal and it won't be as accurate as lead screws but it's the way I'm going for mk1. Would putting 2 lock nuts on the bar with the 2 flat ends facing each other, backed with washers and a strong spring in between the 2 actually help at all? Obviously the nuts will be captive in the bracket of the sliding part and the ends will be held with bearings, but would it be worth taking the time to fashion a bracket where I could spring in between the 2 nuts?
    I'm not looking for a highly accurate machine. If I can stay within a mm over the length (A4 size) then I'll be happy. I'm using mk1 as an exercise in getting the thing to move and working well with the PC.
    I've got my tin hat on ready so fire at will! :naughty:
    What I have done is to use "long nuts" (I don't know the right name sorry) with a cut/split through one side between the two holes....also I found that threaded rod is not very accurate, so I recut all the lengths of threaded rod with a standard DIN Die nut. This got me a thread that was the same along its whole length....
    The "split" nut was then slightly squashed in a vice, till it was a firm fit on the rod. I then used metal polish and ran the nut up and down about 10 times with an electric drill, to "lap" the two together. Clean well and lubricate with a light grease or oil, best quality.......I use two hose clamps to keep the gap where it is....
    This is not as good as proper threads for CNC of course, but gives a surprisingly good system that can make pcbs quite accurately......I measure about 0.02 to 0.04mm back lash....or about 0.00158" Max.
    I would use a good silicone oil if I could find one, but its not as easy as I though....I have not repolished yet, but eventually I expect I will need to do that.....I have used the vice once to close up the split again....
    Its a cheap way, costs very little, but proper screws and nuts are always better....I also use skateboard bearings for the radial loads and axial bearings for the axial loads.
    This site gave me my inspiration:-
    http://buildyourcnc.com/default.aspx
    regards
    Andy
  1. "Hacking" and "Modding"
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  3. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  4. "Racks" VS "ball screw"
  5. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
