    Thanks for the reply.
    Im looking for a 12L075, basically a 12 tooth pulley to suit a 075 (19.1mm) belt with a 6.35 or less pilot to suit a nema 23. I really dont understand what consequences changing the pulley will have, I have emailed the designer and waiting for him to get back to me (he is very responsive by the way). He had to use a bush when building his machine too but it was a different size to the one I would have to buy from the UK. I did ask about the bush in the first place and he told me he got it from a local hardware store.
    Is it me or do the hardware stores in the USA stock everything!!!!!!
    It would appear that 'McMaster-Carr' stock nearly everything the US has ever produced in plastic or metal ... http://www.mcmaster.com
    Tim G-C
    “I disapprove of what you say, but I will defend to the death your right to say it.”
    (attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
  1. What size stepper motor do I-need.
    By irving2008 in forum Stepper & Servo Motors
    Last Post: 15-06-2017, 09:18 AM
  2. misaligned keyway - stepper shaft vs pulley
    By dsc in forum Stepper & Servo Motors
    Last Post: 25-02-2014, 03:25 PM
  3. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  4. Increasing timing pulley bore size from 3mm t0 3.175mm
    By divdav in forum Gantry/Router Machines & Building
    Last Post: 14-05-2011, 09:45 AM
  5. What stepper motor size (torque)
    By ZeroCount in forum Stepper & Servo Motors
    Last Post: 09-02-2009, 11:54 PM
