14-06-2010 #10
Thanks Jeff,
Ive managed to find the pulleys but the bore is a problem, I can overcome the problem by getting some bushes machined which isnt a problem, I was looking for a cheaper way though hence the post.
The timing belts are pretty easy to find but the L075 open ended ones aren't. I have contacted a few suppliers by email and waiting for them to come back to me. Hopefully Ill get some prices tomorrow. After looking around more and more I would love to use R&P but I cant afford it. The cutting bed size is important to me as I cut plastic sheet (currently using a hand router which is a nightmare). Therefore I will have to try the belt system first and see how it works out.
Thanks again fella, its so nice to have a forum here in the UK :)
What size stepper motor do I-need.
By irving2008 in forum Stepper & Servo MotorsReplies: 46Last Post: 15-06-2017, 09:18 AM -
misaligned keyway - stepper shaft vs pulley
By dsc in forum Stepper & Servo MotorsReplies: 9Last Post: 25-02-2014, 03:25 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Increasing timing pulley bore size from 3mm t0 3.175mm
By divdav in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-05-2011, 09:45 AM -
What stepper motor size (torque)
By ZeroCount in forum Stepper & Servo MotorsReplies: 5Last Post: 09-02-2009, 11:54 PM
