... You can't preheat the cast iron mould because you don want to detemper the spindle. You can't upend it and pour from the front because you can't remove the spindle to clean it up afterwards...
I wouldnt have thought it would have been hot enough to detemper the spindle... Its been suggested it needs to be at 150degC or so, the bearing metal melts at 380degC-ish, neither of which are hot enough to detemper a steel spindle, agreed?
