Thread: Reconditioning a Relmac lathe
21-07-2008 #13
I think you may be right, but if that was the case why did it work OK at the other end? Maybe something to do with heat distribution... and when I did have the gap in the shim it failed to fill OK on the other side????
Obviously I'm not chanting the right incantations when i do the pour. The main issue with cutting the shim is that it makes the shaft very hard to remove if its solid metal round it. What I might do is taper the shim back towards the outside so that there is a full gap by the shaft and I can get a junior hacksaw blade in the slot to remove the metal where the shim tapers to fully slot the bearing to remove the shaft
I did have one uninterrupted pour... it flowed out four of the 5 vents but not the last one as the pictures show!
Funnily enough I was thinking on the lines of a wooden dam and it would be easier to make into the right shape - what I actually need are two 50mm x 3mm discs with a ~37mm dia x .5mm deep recess and a 32mm central hole with some cutouts for vents... maybe I should make some up...
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM
