Try ERIKS where i got mine from. It is an expensive outlay but comparible to screws, I will try and update my build log soon. Don't buy the rubber belt a complete false a oconomy, Time gets less and less everyday, i have to finish putting my southbend back together to make room to finish it off (tiny garage)
16-06-2010 #2
Its 5mm pitch and 15mm wide
16-06-2010 #3
Have a look here http://www.technobots.co.uk/acatalog..._Cams_404.html for your pulleys and belts, this is where u got mine from, if you cant see what your after give them a ring, thats what i did. They are very helpfull!
23-09-2010 #4
+1 on helpful!
AdCNC - Now that your machine has been running a while ... i appreciate its servos not steppers ... but any comments / after thoughts on belt size/pitch/width/type, gear size/material, ratios or the design you used to allow for tension adjust?
If you remember .. what were the specs of the belt + pulleys you used?
BIG THANK YOU!
*looking 90% like it will be SY60 steppers (48v BiPol Parrell) for 2x Xaxis ballscrews 1100mm long each hauling 35kg of Y + Z + router
16-06-2010 #5
Thanks, ill take a look
16-06-2010 #6
technobot do not do the sizes or open ended belt but they are very helpful
Calculating timing belt lengths
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 10-12-2015, 11:32 AM -
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
timing belt instead of lead screw
By deannos in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 06-03-2012, 08:25 AM -
Timing belt drive concept, would this work?
By psiron in forum Belt Drive, Pulleys & TimingReplies: 8Last Post: 16-06-2010, 03:31 PM -
Timing belt instead of rack!
By ptjw7uk in forum Belt Drive, Pulleys & TimingReplies: 8Last Post: 18-12-2009, 12:49 PM
