    hi guys i have a ps407 power supply that is acting up
    basicly it works fine not connected to anything no faut light outputs fine too
    but connected to a stepper driver it works fine for about 10 mins the goes to red light fault i know its not the driver as i have 4 of them and they all run fine on the other supply i have i just dont like running 4 drives of two power supplys
    just wondered if anyone has had this problem???
    is it fixable or is this bin food lol
    just seems like its over heating under load and shutting down
    cheers guys for any help
    What drivers, and what is the DC voltage at the driver?
    four drivers from one PS407 is cutting it fine.
    For three axis with the PM542 we suggest two PS407 power supplies and this is the same for four axis.
    Quote Originally Posted by Gary View Post
    sorry did not make it clear i did have 3 ps407 supplys but now only running 2 and drivers are pm542 x 4
    so running 4 drives from 2 ps407 not all axis running at the same time at the moment lol using rotory table not using Y but driver powered
    might unplug the driver
    have to reconnect the power supply togive you voltage at driver forgot what it was ???
    45.8v at driver i run very short wire
    45.8V is too high.
    The PS407 should be about 40V, can you double check?
    45.8V is too high.
    now showing 46.5v ??
    ok, can you check the other power supply to see what the voltage is.
    This seems a bit high, and could be faulty?
    Are you sure it is not a ps487?
    Strange, they should be 40V and 0A and 38V at 7A.
    Can you check the AC, maybe you AC is very high?
    its over a year old from another vender so no warrantee but thanks for all your help
    its just strange that it works fine for 10mins then red fail light come on
  10. Ok, it is most likely getting hot.
    Have you tried adding a fan?
    But it is most likely better to replace.
  1. Power Supply Suggestions please..
    Last Post: 30-01-2013, 06:37 PM
  2. PS806-5 Power Supply
    By Washout in forum General Electronics
    Last Post: 11-11-2012, 03:07 PM
  3. Replies: 0
  4. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
