Sorry forgot this one.
Go to the Machsupport.com site and under downloads > Mach and lazycam > right at the bottom download the screen 4 program.
Unzip and drop into a folder called screens inside mach3.
Open Screen 4, load your screen, standard one is called 1024.set.
You now need a new button somewhere on the screen, click the button in the left menu then click on the screen to get it to appear, drag and resize it to where you want it.
Then double click the new button and it's edit box will appear, near the bottom it says button label text, type in Park.
Click the radio button for G Code function and in the box at the side type in X0.0 Y500.0
Save the screen under a different name like barry.set
exit screen 4,
load Mach up, go to View > Load Screens and select barry.set and it will have the button you need, press it and it buggers off to X0.0 Y500.0
.John S -
The Following 2 Users Say Thank You to John S For This Useful Post:
18-06-2010 #2
Hi John,
More great stuff, thanks! Wow, this opens up alot of possibilities. Since this new button can take a hotkey, I was thinking of buying a USB keypad (i.e. just the bit on the far right of most keyboards containing the numbers and 3 LEDs) and putting this somewhere handy. Looks like they will fit in your hand. I can then be right next to the cutter and jog the machine as before, but add another hotkey for park. Think these keypads are about £10. Lovely!
Barry
Model Engineer Exhibition & Maker Show @ Sandown Park
By ModelEngineer in forum General DiscussionReplies: 0Last Post: 19-11-2013, 03:53 PM -
RFQ: West London, Park Royal, Acton Area. 4 holes CNC drilling in my new Spindle mount & Z
By stuboy in forum Projects, Jobs & RequestsReplies: 2Last Post: 16-08-2013, 06:40 PM -
Adding earth cable to 2.2Kw Chinese Spindle
By Dwayne Dibbley in forum Generic Chinese SpindlesReplies: 4Last Post: 13-03-2013, 04:04 PM -
Model Engineer Exhibition - Sandown Park, 2 - 4 Nov
By irving2008 in forum General DiscussionReplies: 2Last Post: 18-10-2012, 10:39 PM -
NEW MEMBER: good morning from menlo park
By Douglas114 in forum New Member IntroductionsReplies: 1Last Post: 06-12-2010, 01:56 PM
