    The pulleys either have grub screws which tighten down on the shaft OR holes for you to screw into the shaft (drill and tap required).
    With regards to the belt widths im sure one of the cnc warlords here will be able to help you with that ;)
    Hello psiron,
    Thanks for the quick reply. One question answered. I know they will:)
    Jordan
    I took one look at the RS prices and immediately went for the XL, don't know if yours are similarly priced though
    10t sounds a bit small, only 4 engaged, not a lot of leverage. Being an accuracy freak I'd suggest you pre-tension it way beyond the rating for the motor shaft.
    This means a lay shaft with bearings either side of the driving pulley. OTOH once you do that you get a second set of pulleys in the equasion so you can beef up the drivers above 10t and get a nice fat shaft through them.
    I've just had the first run out of mine - 10t 5mm pitch 16mm wide on the X axis and same but 10mm wide on Y axis....I have just got them running through pieces of rubber air hose as a temp direct drive.
    For the Z I have used an old G cramp for the acme screw and a sprung 2nd nut to take the backlash up...I'm trying to keep the cost down and so far its working quite well (well nothing beat me so far)
    The 10t pulleys are small but it seems to be working ok and next I'm going to reduce by about 4:1 (fingers crossed for fathers day) - I managed to tap out 8mm for 8mm shaft and carry on using the skate bearing theme :)
    I have just done a video on youtube if anyone is interested www.youtube.com/user/8iggles#p/a/u/0/FTQ2c-HvNvI Dont expect too much theres still loads to do I just pushed myself to get a run and prove I'm on the right track!
    Cheers Shaun
  1. Timing Pulley/Belt sizing software
    By m_c in forum Computer Software
    Last Post: 12-04-2014, 03:33 PM
  2. 1:1 ratio - pulley sizes
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 12-04-2014, 01:30 PM
  3. pulley center distance vs. belt tension
    Last Post: 13-01-2014, 10:48 PM
  4. Where can i find belt and pulley for a spindle?
    By JW1977 in forum Marketplace Discussion
    Last Post: 12-11-2013, 08:03 PM
  5. AC Motor upgrade - pulley sizes
    By birchy in forum Linear & Rotary Motion
    Last Post: 21-06-2013, 10:49 PM
