Thread: Belt drive and pulley sizes
17-06-2010 #4
I took one look at the RS prices and immediately went for the XL, don't know if yours are similarly priced though
10t sounds a bit small, only 4 engaged, not a lot of leverage. Being an accuracy freak I'd suggest you pre-tension it way beyond the rating for the motor shaft.
This means a lay shaft with bearings either side of the driving pulley. OTOH once you do that you get a second set of pulleys in the equasion so you can beef up the drivers above 10t and get a nice fat shaft through them.
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulley center distance vs. belt tension
By dsc in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 13-01-2014, 10:48 PM -
Where can i find belt and pulley for a spindle?
By JW1977 in forum Marketplace DiscussionReplies: 5Last Post: 12-11-2013, 08:03 PM -
AC Motor upgrade - pulley sizes
By birchy in forum Linear & Rotary MotionReplies: 7Last Post: 21-06-2013, 10:49 PM
