Thread: Belt drive and pulley sizes
Were the nuts spaced far apart? What are the nuts made of? I could make one out of my wife's chopping board. Are 16mm wide belts useable for 16mm hub width pulley?
18-06-2010 #2
The nuts are the are the threaded bit of the of the clamp frame I just cut off most of the frame I didn't want leaving enough to mount to...the second nut is the threaded bit if a second clamp with a tab left on to stop it turning...they are about 1/2" apart but this depends on your spring ( mine was off an old washing machine I think ) I would think you could make one from a chopping board but for me I would have had to get a tap to suit whatever thread I could get and this would cost money!! The square threads work great and even with the sprung nut it is very easy to turn.
The 16mm belt I got, fits ok on the 16mm pulleys and there is a little side clearance...There will be some stretch in the belt but, I only intend to cut foam at first so It will be fine for me
18-06-2010 #3
Attachment 2301
Its work in progress but you get the idea
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulley center distance vs. belt tension
By dsc in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 13-01-2014, 10:48 PM -
Where can i find belt and pulley for a spindle?
By JW1977 in forum Marketplace DiscussionReplies: 5Last Post: 12-11-2013, 08:03 PM -
AC Motor upgrade - pulley sizes
By birchy in forum Linear & Rotary MotionReplies: 7Last Post: 21-06-2013, 10:49 PM
