Thread: Belt drive and pulley sizes
18-06-2010 #11
Attachment 2301
Its work in progress but you get the idea
18-06-2010 #12
Stretch in the belt should not actually affect accuracy, so long as you pre-tension it beyond the expected load.
Just my .02p
19-06-2010 #13Stretch in the belt should not actually affect accuracy, so long as you pre-tension it beyond the expected load.
Jordan
19-06-2010 #14
@8iggles
That's a clever solution you got there. That's what I should do also.
19-06-2010 #15
[IMG]
[/IMG]
Here's a few picture of my design. I just hope it will work.
Jordan
19-06-2010 #16
Nice design - and no reason why it shouldnt work. One criticism if I may; the Z-configuration of the Y-motion belt will be problematic. its inducing a rotational moment on the z-axis which loads the bearings on the high side more than those on the low side. This will wear the bearings unevenly and could result in cantilever stiction. I would redesign that to put in another jockey pulley and make the y-motion belt flat along its length .
19-06-2010 #17
Strange I was thinking of the same thing while driving on the way to the grocery just 3 hours ago. I could arrange the jockey pulley such that the belt's ends will be located lower. That would also eliminate the need of different sizes of gantry uprights! And it would look much better too.
Thanks for the helpful suggestion. I hope you'll find more to correct :)Last edited by j2sip; 19-06-2010 at 03:52 PM.
19-06-2010 #18
Here's the pulley placement redesign as suggested by irving2008. The belt barely cleared the bottom V bearings. It now looked simplier despite the addition of another set of bearing pulley. Thanks a lot for your help.
jordanLast edited by j2sip; 19-06-2010 at 06:22 PM.
19-06-2010 #19
That looks better; the belt tension will pull the tops of the uprights in so depending on the tension and the thickness of the uprights you may need to consider a compression member above or at the belt line. this could simply be a section of tubing, so I'd leave it until you've built it and see if there is measurable deflection.
19-06-2010 #20
Nice design, one small thing, add a support bearing at the side of the large pulley on the X axis cross shaft to prevent the shaft from whipping and also to keep tension without it bending the shaft.
.Last edited by John S; 19-06-2010 at 09:55 PM. Reason: This keyboard can't spel
John S -
Timing Pulley/Belt sizing software
By m_c in forum Computer SoftwareReplies: 4Last Post: 12-04-2014, 03:33 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulley center distance vs. belt tension
By dsc in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 13-01-2014, 10:48 PM -
Where can i find belt and pulley for a spindle?
By JW1977 in forum Marketplace DiscussionReplies: 5Last Post: 12-11-2013, 08:03 PM -
AC Motor upgrade - pulley sizes
By birchy in forum Linear & Rotary MotionReplies: 7Last Post: 21-06-2013, 10:49 PM
