    Hi
    Before it goes on ebay is anyone interested......
    I have a 1m (39.37 inches in old money) length of C25 (origionally from Eurobearings) rail and one linear recirculating bearing for sale. The bearing has hole centres (dia 7mm) 45 x 57mm, the "bed" of the bearing is 58x70. Very stiff, light use, no play (preloaded), very small amount of surface corrosion but none on bearing face. Smooth and very strong. Used to hold z axis (big servo, screw, Kress) no problems. Bearing has wipers and grease nipple.
    for rail dims see:
    http://www.euro-bearings.com/mgsrail.htm
    All bolted with 17 bolts to a bit of Aluminium bar 3 inch by 3/4 by 1m which is tapped 2x M8 at each end for mounting? I can take this off if not wanted. Sensible offers? I suggest buyer collects as it's heavy. 9kg with Aluminium, about 4-5 without.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
ID:	2344Click image for larger version.
ID:	2345Click image for larger version.
    Can anyone suggest what its worth?
    Tom
  4. Its Abba Rail by the look of it.
    If it is its the rail would be BR25R-L1000-N and the bearing would be the BRH25A.
    We sell the bearings for £42 and the rail would be £80.00
    This is new and there is also VAt to include.
    Second hand would be about 25% of this, but you really need two bearings per rail and would normally have two rails.
    Hi Gary
    Thanks. It was origionally source from Eurobearings, only ever had one carriage. That gives me a really good value though. Many thanks.
    Tom
    Consider it sold, many thanks.
    Tom
  1. What is the best way to mark out for bearing blocks and linear rails?
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 18-05-2014, 02:08 PM
  2. Open Rail, open source linear rail?
    By Musht in forum Open Source Designs & Plans
    Last Post: 15-06-2012, 12:21 PM
  3. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 05:26 PM
  4. FOR SALE: 25mm round rail bearing blocks
    By D-man in forum Items For Sale
    Last Post: 31-10-2011, 09:26 AM
  5. THK linear bearing rails
    By Tonyel in forum Rails, Guideways & Bearings
    Last Post: 01-11-2008, 03:21 PM
