  1. No idea, but i have one of those going spare removed from my late father's flat. Unless its a Stannah you cant sell them (mines a Brooks) and they go for peanuts on eBay.... I haven't found an obvious use for it... (I was thinking motorised car jack thingy, but don't think its strong enough)
    A slight aside to this.
    I just bought a display cabinet off Ebay, similar to the ons you see in big departmental stores. L shaped 30" high at the front counter bit with a 5' display unit at the end. Paid £50 for it.
    Doesn't sound impressive until I tell you it was made from 45 x 45 alloy extrusion with all the corners, brackets bolts etc needed to hold it together.
    I wonder what it would have fetched if it had been listed as Alloy extrusion suitable for a router ?
    John S -
  3. Quote Originally Posted by irving2008 View Post
    Well finally got round to removing it form the flat yesterday... in doing so I liberated:
    14 feet of Ali beam - now cut into 2 equal lengths - once tidied wil make two 6.5ft of 150mm x 100mm W-shaped extrusion -side beams for something
    8ft and 6ft rack sections
    good selection of m10 and m12 bolts and nuts
    24v battery pack and charger
    motor and gear box, poss use for powered feed?
    six 40mm dia x 30mm long 10mm bore nylon rollers and other nylon/ptfe blocks
    2 aluminium castings/side plates about 4kg - will melt down i reckon
    4 roller operated push switches - good for limit switches
    2 microswitches (cover interlocks)
    two charging plates used for recharging when the chair was docked, liberated 4 x 150mm x 10mm x 3mm brass strip, good for new gib strips for lathe
    LEDs, piezo beeper, motor controller PCB
    Not bad for 30min work (and 20 of that was with the hacksaw...)
  1. New Gantry Ideas
    By Tomnewry in forum Gantry/Router Machines & Building
    Last Post: 05-02-2014, 10:00 PM
  2. BUILD LOG: 5'x3' Ideas and build.
    By Wal in forum DIY Router Build Logs
    Last Post: 29-12-2012, 02:03 AM
  3. New machine Ideas
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 19-09-2012, 10:18 AM
  4. Need some ideas
    By jpcnc in forum Machine Discussion
    Last Post: 29-01-2011, 07:56 PM
  5. Ideas and inspiration....?
    By Tom in forum General Discussion
    Last Post: 10-08-2010, 01:09 AM
