Hi Shaun,
I hope I'm understanding your intention. I'm no spindle expert, but a thrust bearing will only allow you to drill holes because it cannot take side loads. Therefore a pair of angular contact bearings sounds better. A spindle often runs at high speed, and therefore you might also want to consider the ceramic type of bearing.
Bit more detail about what you want to machine might help others with a spec for you.
Hi Thanks for the reply, I have found a couple of roller type thrust bearings in a rummage through a box of old bearings I got from my Dad...I was going to use a couple of ball races and a thrust bearing.
I don't need anything too robust as I'm only going to be cutting depron and balsa / liteply at first, but was worried about the speed...My thoughts were like a model aircraft engine is reported at XX BHP at like 17,000 revs ( although I have never measured or seen one at this speed ) now these are just ball races and have temp and nitro working against them?? It would be good to continue the 22mm OD theme of the skate bearings but the shaft on them is only 8mm
Just noticed your Avatar - Is it your own design? Are you going to green acres fly in this weekend, thats in your neck of the woods ?Last edited by 8iggles; 23-06-2010 at 06:11 PM.
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
type of shafting for round linear bearings
By quickcut in forum Rails, Guideways & BearingsReplies: 2Last Post: 11-08-2013, 10:17 PM -
FOR SALE: rails, screws, bearings and spindle
By wilfy in forum Items For SaleReplies: 16Last Post: 10-04-2013, 01:50 AM -
spindle bearings overheating
By Andrew Wilding in forum Spindles & Drive MotorsReplies: 9Last Post: 15-05-2011, 01:21 PM -
FOR SALE: Elte type spindle 0.55kW 12000rpm 220AC 3-phase
By Vladimir_MD in forum Items For SaleReplies: 3Last Post: 16-05-2010, 06:48 PM
