Thread: 11" Harrison
    Alfaman20's Avatar
    Location unknown. Alfaman20 Last Activity: Has a total post count of n/a. Referred 6683 members to the community.
    I need a feed shaft for my 11" Harrison 40" between centres. The one that drives the auto longitudenal feed. The lathe has a Norton type gearbox. Has anyone any suggestions where I might buy one?
    Isn't it just a straight rod with a keyway in it ?
    John S -
    Alfaman20's Avatar
    hi Hobnob
    As far as I know yes it is a straight shaft with keyway but as mine has either been broken and removed or at some time simply removed I have no idea what it should look like at each end nor do I know what diameter it should be. What are your thoughts? If I had an engineering drawing of one I guess I could have one made but without that I need some one to tell me where to obtain either a new or used one. Many thanks for the reply
    John R
  4. Try emailing Tony at lathes.co.uk or try http://www.gandmtools.co.uk/makerspages/harrison.html
    Alfaman20's Avatar
    I have alreaqdy contacted the obvious sources with no luck hence the request for help
    Thanks anyway Irving2008
    John R
    Hi
    Have you tried these fellows, they claim to hold all the drawings?
    http://www.600uk.com/products/machine.asp?id=142
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  1. My CNC converted Harrison M250
    By M250cnc in forum Conversion Build Logs
    Last Post: 14-01-2022, 09:20 PM
  2. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 07:15 PM
  3. "Hacking" and "Modding"
  4. "Racks" VS "ball screw"
  5. Harrison M250
    By Arthur Kingdon in forum Milling Machines, Builds & Conversions
    Last Post: 14-06-2010, 08:36 PM
