  1. #13
    I've updated the previous gantry stiffness spreadsheet with a few minor tweaks (one slight error corrected, factor 4 re-located). New version 3 below:
    This will calculate the vertical deflection of various types of section, plus twisting and resultant tool deflection due to cutting forces (on routers etc.)
    Instructions for use
    1. Top left boxes:
    Load applied to section
    Cutting force in that material (see sheet for suggested values - thank you Irving2008 for these values, borrowed from stepper motor calc sheet!)
    Length of beam
    2. Next set of top left boxes are for the material.
    Defaults are steel, but there is a lookup table off to the left for aluminium or wood (Douglas Fir). Copy over the 3 relevant values into Young's modulus, Density, and Modulus of rigidity.
    3. Geometry
    The shape inputs are next in rows 15 to 17. Purple boxes.
    4. Results
    The yellow boxes in row 25 and below show various outputs.
    Enjoy !
    Attached Files Attached Files
  1. Z axis assembly - unsupported rail for very limited movement
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 10-10-2012, 12:44 PM
  2. round, supported or profiled rail?
    By mocha in forum Rails, Guideways & Bearings
    Last Post: 26-07-2012, 03:44 PM
  3. WANTED: 2 x 20/16mm supported round rail
    By D-man in forum Items Wanted
    Last Post: 30-10-2011, 11:08 PM
  4. Profile v Supported Round Rail
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 15-09-2011, 09:29 PM
  5. FOR SALE: Round linear rail and bearings
    By routercnc in forum Items For Sale
    Last Post: 19-08-2010, 05:17 PM
