04-07-2010 #16While this seems to make good sense it would appear to me to transmit any imperfections in the ali section to the rail and carriage. If you go down this route then there is no reason to use the precision rail and and I would just mount more bearings and run it on the Ali sections full stop.A suggestion (from a non-plasma expert!) is to consider running a simple bearing from the back of the Z axis plate onto the top and bottom of the upper 40mm rail. This would give a bit more support to reduce the sag
Barry, I see that is how you have done it on the x axis on your machine, do you get any problems with surface Finnish or the bearings compacting the Ali and causing a groove?
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM -
round, supported or profiled rail?
By mocha in forum Rails, Guideways & BearingsReplies: 0Last Post: 26-07-2012, 03:44 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM -
FOR SALE: Round linear rail and bearings
By routercnc in forum Items For SaleReplies: 5Last Post: 19-08-2010, 05:17 PM
