05-07-2010 #19Thought it looked expensive....It was drawn on Solidworks
I see, still seems a bit overkill :heehee:, couldnt you just use a circular spring loaded mount on the torch?That is a vital part of a Plasma system
It is a 'Floating switch'
What happens is Z axis lifts up and moves to its pierce position, the Z axis then lowers until the Torch makes contact with the material.
I will be inrested to know how you get on as the ali beam i just bought uses a similar idea but with rubber bearings and I was wondering how well it would work if I replaced them bearings.Ross,
Yes, there are some risks from bearings on ali section. My machine is still some way from running yet so I don't know how it will cope with bearing surface wear.
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM -
round, supported or profiled rail?
By mocha in forum Rails, Guideways & BearingsReplies: 0Last Post: 26-07-2012, 03:44 PM -
WANTED: 2 x 20/16mm supported round rail
By D-man in forum Items WantedReplies: 4Last Post: 30-10-2011, 11:08 PM -
Profile v Supported Round Rail
By Rogue in forum Rails, Guideways & BearingsReplies: 5Last Post: 15-09-2011, 09:29 PM -
FOR SALE: Round linear rail and bearings
By routercnc in forum Items For SaleReplies: 5Last Post: 19-08-2010, 05:17 PM
