Ok, so maybe that was too much of a mind dump!
In summary, for the machine being considered:
There seems to be some benefits to the lean back style of gantry where the C of G ends up in the centre of the side rail bearings. This reduces the bearing moment and reduces the risk of binding.
There is a formula for the ideal Z location for the X axis ballscrew which drives the gantry, which ends up being near the Z location of the tool
During constant velocity cutting the ballscrew forces are dominated by the cutting forces
During acceleration, the inertia of the gantry is only a small part of the total force, which is again dominated by the cutting forces
With well chosen geometry (ballscrew/rail/tool), the side rail bearing moment is small, meaning the bearings can be placed close together give more overall gantry movement along the X axis.
Finally, as mentioned in another thread, here is a further update to a spreadsheet calculating deflections and twisting of a gantry. Now added a further calculation for the gantry bending when cutting in the Y direction. So the gantry vertical deflection due to spindle weight, twisting due to cutting in X, and bending/lozenging due to cutting in Y direction can now all be approximated. This gives a rough minimum tool deflection. Comments and errors gratefully received . . .Last edited by routercnc; 15-07-2010 at 09:43 PM. Reason: updated spreadsheet 15/07/10
The Following 3 Users Say Thank You to routercnc For This Useful Post:
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
A concept design for a cnc machine
By madprof1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-12-2012, 10:40 PM -
Router design thoughts
By m_c in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 11-09-2012, 07:06 PM -
FUNdaMENTALS of machine design
By Ross77 in forum General DiscussionReplies: 1Last Post: 13-08-2010, 12:58 AM -
Full Machine Design/Display
By Lee Roberts in forum Computer SoftwareReplies: 12Last Post: 29-05-2009, 09:33 PM
