13-07-2010 #4
As I'm sure you know, for the best stiffness to weight ratio in both bending and torsion you basically want to move the material as far away as possible from the neutral bending axis (and have a closed section for torsion), which means ideally a round tube but box section is pretty good and much easier to work with. If you look at bicycle frames where they care a lot about both stiffness and weight the tube forms are generally close to circular, elliptical or a rounded off box
I like the idea of an option for using box on the side supports - it always looks like the weak point on a lot of gantry designs and it would be nice to be able to quantify that.
I'm also interested in the idea of placing bearings close together - I have been designing to get them as far apart as possible working on the principle that it's not expensive to make the axes a little bit longer and it will reduce the effect of any flex in the bearings. It will also let me put the leadscrews in a convenient position rather than the best place to minimise the forces on the bearings - any comments?
Good thread.
Mark
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
A concept design for a cnc machine
By madprof1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-12-2012, 10:40 PM -
Router design thoughts
By m_c in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 11-09-2012, 07:06 PM -
FUNdaMENTALS of machine design
By Ross77 in forum General DiscussionReplies: 1Last Post: 13-08-2010, 12:58 AM -
Full Machine Design/Display
By Lee Roberts in forum Computer SoftwareReplies: 12Last Post: 29-05-2009, 09:33 PM
