04-10-2010 #8
Hi williamturner1
You might be reading off the wrong rows.
I've compared the 2 shape:
'I beam' width 100mm, depth 200mm, flange 10mm, web 7mm
RHS width 120mm, depth 80mm, wall 3mm
Assuming length 2000mm, and your weight 60kg, and vertical Z deflections are:
I beam 23 microns
RHS 393 microns
Which tallies with your jumping experiment, showing the vertical stiffness difference, where the I beam is much stiffer.
Unless you had a lever arm to jump on (which was very stiff), then you would not be comparing the torsional performance which I would expect to be worse for the I beam.
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
A concept design for a cnc machine
By madprof1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-12-2012, 10:40 PM -
Router design thoughts
By m_c in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 11-09-2012, 07:06 PM -
FUNdaMENTALS of machine design
By Ross77 in forum General DiscussionReplies: 1Last Post: 13-08-2010, 12:58 AM -
Full Machine Design/Display
By Lee Roberts in forum Computer SoftwareReplies: 12Last Post: 29-05-2009, 09:33 PM
