Thread: Need helpwiring up from scratch
12-07-2010 #19
You need to step back and check thru logically, read up on what you can and if you can't understand anything ask first.
Don't start experimenting as that the way to damage components.
It only takes one crossed wire to damage a component.
Wire up the power supply and test it.
Make sure you know which is positive. and what voltage it's putting out.
Then connect this to the BOB, Do you have a power light ? are you getting 5 volt and 12 volt from the auxiliary supply points at the side of the power in ?
Connect the power supply to the drivers, do you get the power on LED lit up ?
Now connect the steppers to the drivers taking note of how they need to be wired.
Do the stepper clunk and lock on switch on ?
That proves the power side first.
As an aside what computer are you using ? and does it have an inbuilt parallel port or an add on card.?
There is nothing wrong with Roy's boards, I have fitted well over 70 - 80 different models and never had any trouble with them.John S -
BUILD LOG: 1250 x 1250 cnc router (from scratch)
By Danielroyal25 in forum DIY Router Build LogsReplies: 56Last Post: 08-08-2014, 07:35 PM -
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Starting from scratch, what would you use as a base for a CNC metal lathe?
By m_c in forum Lathes, Lathe Rebuilding & ConversionsReplies: 4Last Post: 23-01-2011, 05:37 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM
