Thread: Need helpwiring up from scratch
12-07-2010 #33
Got another problem,since I know the Z and Y axis work I've been having a dabble to try and get to know MAch3 functions and how it works.
However in the Motor tuning setup I cannot get anything out of the motors,they jut won't turn....they work fine if I load a G-code.
Going through the PDF of how to set up Mach3 and this is the first thing it explains to do but it ain't happening for me :cry:any ideas?
Thank yer vey kindly
BUILD LOG: 1250 x 1250 cnc router (from scratch)
By Danielroyal25 in forum DIY Router Build LogsReplies: 56Last Post: 08-08-2014, 07:35 PM -
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Starting from scratch, what would you use as a base for a CNC metal lathe?
By m_c in forum Lathes, Lathe Rebuilding & ConversionsReplies: 4Last Post: 23-01-2011, 05:37 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM
