15-07-2010 #1
Hi All
Looking to move house and so everything has to go
I have the following for sale (+ more as I remember), all is for collection from Newport in South Wales, More info/pictures on request.
Taig 4 axis CNC Mill, comes with the following:
- Standard motor + ER16 spindle
- Kress 800 FME (1hp 10k - 20k rpm) spindle & mount
- 3 inch Tilt/swivel milling vice + 2" quick release vice
- CNC rotary table + chuck (140oz/in)
- 35+ end mills, fly cutter and other tooling
- full set of er16 collets
- 3x 320 oz/in stepper motors
- 4x MCP stepper controllers
- 2x MCP PSU's + breakout board
- Sieg Collant pump & resevoir & coolant (nozzles, tubing etc)
- Diamond drag engraver
- HP P4 pc with 19" flatscreen
Cost was well over £3k, am looking for £2000
Sieg C3 Mini Lathe with Sieg DRO's and Spindle speed readout
- 3 inch chuck
- 4 inch chuck
- er16 collet chuck
- Tail stock drill chuck
- dead centre
- live centre
- loads of tooling (cutters (HSS & carbide), knurler etcm indexable tooling, boring bars)
- tailstock
- QCTP + 3 holders
- Wood lathe set with tools, conversion stuff
- Pen making set including mandrel, blanks, fittings, pen kits etc
- All gears for screw-cutting
Cost over £700, looking for £350
Warco 918 lathe (missing rear splash guard)
- 4 inch chuck
- 5 inch chuck
- face plate
- QCTP
- some tooling
- Metal gears
looking for £375
Axminster MCB1155HD Swivel Head Metal Cutting Bandsaw
- good condition, still on 1st blade, mostly used for aluminium
looking for £190
Powercraft Air compressor + tools
- 2Hp compressor
- air saw
- air cutter
- air drill
- various paint sprayers
- air silicone sealent dispenser
- air sand blaster + aluminium oxide + 15KG of glass beads for blasting
- air regulator that also takes water out of the air and auto oils tools
- air dusters, tyre pumps etc
- few meteres of hose
looking for £100
Powder coating machine (needs an air compressor as above to use)
- Electric Powder coating machine
- foot pedal & dispenser
- 20KG blue gloss powder
- 20KG grey texture powder
- 0.5KG brown powder
- small toaster oven for curing
Powder boxes alone cost £100 each and the machine cost over £200 with extra bottles
looking for £230
Er32 Collet chuck x2 (MT3 & straight shaft) + plus full collet set (new)
- 2-20mm collet set (19pcs)
- 2 x collet chucks
looking for £70
Metal polishing machine
- 3 mops, 3 sets of polish hardly used, powerful 300+W motor
looking for £50
New Soba 4" swivel Milling vice £65
New 4" rotary table + chuck £80
I also have lots more such as welders, power tools, bench grinders, bench sanders, pillar drills, tools for measuring, centre drills, DTI's etc
Please PM me to discuss
DJH
15-07-2010 #2
Some pics to get started:
16-07-2010 #3
Ok, just been taking some photos:
Powder Coating machine (also has foot pedal)
Small Oven for Powder Curing
Axminster Metal Cutting Bandsaw
Compressor
Some of the Air tools
Metal polisher
Some of the Bar stock that has to go
An Arc & a Mig welder to go, also have wire, rods, gloves, auto darkening helmet
Warco 918 Lathe
Wood router + table + 2 boxes of router bits (15+)
16-07-2010 #4
Macallister Pillar drill
4" Milling Vice
4" Rotart Table
various Lathe Tooling
Sieg C3 Lathe
Taig 4 Axis CNC Mill
Stepper Motor drivers used on the Taig (4 of)
Same but also showing the PSU's
DTI's, incremental drills, drill & tap set (there is loads of stuff like this)
Pen Making stuff
16-07-2010 #5
Overall view of the Sieg and Taig (coolant bath is also available)
Boxes of Powder coat
An idea of what I need to get rid of
And the other side
An example result of the grey texture powder coat, these are Nema 23 Motor Mounts that I was making on the mill
16-07-2010 #6
you must be gutted...:sad:
How much do you want for the MIG & helmet (ignoring the minor issue of getting it here for now)
16-07-2010 #7
Yeh im not looking forward to it one bit
It's a clarke gasless mig, id say £45 with the auto helmet, also comes with some magnet clamps and a box of mig wire, auto helmet never been used other than to go ooh & ahh for 5 mins while looking up at bright lights. The reason ive not offered shipping on the smaller items is that im working a lot latley and doing 12 hour days, i can never say for sure what days I am home and the added pressure of finding a post office, wrapping stuff up etc I could do without, eventhough I could put some on ebay then.
16-07-2010 #8
That would break my heart having to sell all that :sad: have you thought about a caravan????
IMHO gasless mig is useless. not heard any good reports. but auto helmet and magnet clamps for £45 bargin. I know a poor workman blames his tools but I find low powered welders a nightmare, quality gas and a high power welder is a dream to use:dance:
16-07-2010 #9
Ha i don't think the wife will go for the caravan idea :P
To be honest im not that experienced with welding eqpt, I wanted a Tig & a proper mig welder but could not afford them. I got on a lot better with the gasless mig than I did with the arc welder, started getting nice clean welds after a few days practicing but would not trust myself with anything load bearing or critical with it. Have never welded with gas tho.
DJH
16-07-2010 #10
Interested in the compressor, can you tell me the spec of the compressor.
Visit Us: www.automationshop.co.uk
Affordable bandsaw that's not cr@p
By garson626 in forum Tool & Tooling TechnologyReplies: 4Last Post: 13-02-2014, 12:16 AM -
eBay: large amount of machines on e bay lathes mill plus other stuff
By Dellboy in forum Items On eBay UKReplies: 0Last Post: 17-06-2012, 09:35 AM -
4x6 Metal Bandsaw Mods
By panofish in forum Machine DiscussionReplies: 1Last Post: 09-05-2012, 08:51 AM -
Multico Bandsaw
By newtoid1986 in forum Marketplace DiscussionReplies: 0Last Post: 13-04-2012, 09:17 PM
