Thread: Best way to machine ball screws?
Thanks John.
So do you think I'm wasting my time then? Im not looking to mass produce them just modify or machine the odd one as I need them, Is the diamond tooling essential or just the best value for you given the amount of work you do?
Is that TC tooling or normal HSS?, not sure i would have the skill to get the correct finnish diameter in one pass anyway....I rough down using old tips that have been licked on the top to give more rake, all I'm interested in is getting rid of material, surface finish doesn't matter. Once I'm close I change tips to a diamond coated, small cut to clean up and get a size then the ballance is taken off at one cut.
I have a traveling steady so will this help or is it dangeous to use with such hard metals, tool shatter etc....?
Maybe I wil have to try 2e0poz suggestion with the grinder, sounds messy tho and will have to try and protect the ways.
As another solution Is it ok to turn a 16mm screw down to say 10mm or to the softer core so its easier to thread and then make a sleeve to bring it back up to the size of the bearing?Last edited by Ross77; 20-07-2010 at 01:48 AM. Reason: Missed a bit out
20-07-2010 #2
You need tipped tooling, HSS just won't touch these. You can use normal TC tooling I just use the diamond coated because of the work I do, I machine quite a few screws for other companies, ARC advertise my services others say they do them their selves.
Never tried a travelling steady, never found one that I can get into the right position. I do centre the ends and support on live centres. Sleeving up to a bearing size is OK but use an over size sleeve and turn to get concentric.John S -
have you put ball screws on an X2plus?
By bmbaz in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-05-2014, 06:56 PM -
buying ball screws
By bmbaz in forum Marketplace DiscussionReplies: 2Last Post: 10-05-2014, 03:57 PM -
How to pre load screws
By graham4877 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 14-08-2012, 11:07 AM -
Two ball screws for my x axis and two motors, do i need two drivers?
By luke11cnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 12-08-2011, 12:55 AM -
FOR SALE: Selection of Caphead, countersunk Bolts/Machine screws - mainly stainless steel
By Jimmybristol in forum Items For SaleReplies: 6Last Post: 26-05-2011, 01:10 PM
