Hi George
I'm going to steer clear of the vibration stuff untill I understand it a bit better. But listen to Irving and Freddie and dont use rubber at all.
I kind of agree with you about reducing the vibration but the only way I can see to reduce spindle and motor problems is to use mechanical counter shafts and balances like in a car engine or tuned mass dampers but thats all getting very silly and complicated and I will definatlly be shot for suggestting it.....
Its sounds to me like you are at the same stage as me when I asked if it was possible to convert a pillar drill to a mill. Every one said no dont bother its too much work, but I went ahead and did it anyway ......... and yes it was a lot of work and still isnt fully sorted but I have learnt so much in the process. (and I wouldnt bother again) If its only your time then you have nothing to lose.
At least it would end the debate .......
CNC Router V1.0 (For Cutting Multiple Materials)
By biketrialsdave in forum Gantry/Router Machines & BuildingReplies: 272Last Post: 05-08-2017, 03:37 PM -
DTI holders / bases for nonmagnetic materials
By dsc in forum Tool & Tooling TechnologyReplies: 7Last Post: 11-01-2014, 12:56 PM -
NEW MEMBER: Spanish newbie (with a couple of CNC projects for photography)
By ECardenal in forum New Member IntroductionsReplies: 13Last Post: 09-08-2011, 11:17 PM -
Test cutting materials
By Kai in forum General DiscussionReplies: 6Last Post: 05-12-2010, 10:27 AM -
Z-axis design - help sizing materials please!
By Jonathan in forum Linear & Rotary MotionReplies: 52Last Post: 22-08-2010, 09:10 PM
