Thread: power supply problms
hi guys i have a ps407 power supply that is acting up
basicly it works fine not connected to anything no faut light outputs fine too
but connected to a stepper driver it works fine for about 10 mins the goes to red light fault i know its not the driver as i have 4 of them and they all run fine on the other supply i have i just dont like running 4 drives of two power supplys
just wondered if anyone has had this problem???
is it fixable or is this bin food lol
just seems like its over heating under load and shutting down
cheers guys for any helpLast edited by Scott; 16-06-2010 at 09:46 AM.
16-06-2010 #2
What drivers, and what is the DC voltage at the driver?
four drivers from one PS407 is cutting it fine.
For three axis with the PM542 we suggest two PS407 power supplies and this is the same for four axis.Visit Us: www.automationshop.co.uk
16-06-2010 #3
sorry did not make it clear i did have 3 ps407 supplys but now only running 2 and drivers are pm542 x 4
so running 4 drives from 2 ps407 not all axis running at the same time at the moment lol using rotory table not using Y but driver powered
might unplug the driver
have to reconnect the power supply togive you voltage at driver forgot what it was ???
16-06-2010 #4
45.8v at driver i run very short wire
16-06-2010 #5
45.8V is too high.
The PS407 should be about 40V, can you double check?Visit Us: www.automationshop.co.uk
16-06-2010 #6
16-06-2010 #7
ok, can you check the other power supply to see what the voltage is.
This seems a bit high, and could be faulty?
Are you sure it is not a ps487?Visit Us: www.automationshop.co.uk
16-06-2010 #8
Strange, they should be 40V and 0A and 38V at 7A.
Can you check the AC, maybe you AC is very high?Visit Us: www.automationshop.co.uk
16-06-2010 #9
its over a year old from another vender so no warrantee but thanks for all your help
its just strange that it works fine for 10mins then red fail light come on
16-06-2010 #10
Ok, it is most likely getting hot.
Have you tried adding a fan?
But it is most likely better to replace.Visit Us: www.automationshop.co.uk
Power Supply Suggestions please..
By Ricardoco in forum General ElectronicsReplies: 37Last Post: 30-01-2013, 06:37 PM -
PS806-5 Power Supply
By Washout in forum General ElectronicsReplies: 7Last Post: 11-11-2012, 03:07 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
