  1. #4
    John i don't Keith needs to go that far with what he wants really. I bought all the parts to build a foam cutter before starting myself. Keith as i was going to base my original build on the same machine for exactly what you are doing The cheap driver should be fine as i have two here myself and used them on a much bigger machine. You can get the draw slides as a multi pack buy from Screw Fix, i would use ACME 12 X 3 instead of the threaded rod they suggest as it will give you the higher speeds. At the end of the day you are cutting foam not a hard dense material so no need for all the extra expense. If i may even suggest you look at belts as well as you could even loose some of the motors by linking each side, use one motor for each plain. By the time you get that Obeche over you foam should look a treat.
  2. The Following User Says Thank You to Swarfing For This Useful Post:
  1. laser cutter/engraver rebuild build log
    By gavztheouch in forum Laser Machines & Building
    Last Post: 10-11-2015, 05:37 PM
  2. Hot Foam cutter for RC aircraft
    By rckeith in forum Hotwire Cutting Machines
    Last Post: 10-08-2015, 08:32 AM
  3. CNC hot wire cutter
    By Nstocks in forum Machine Discussion
    Last Post: 22-05-2014, 07:54 PM
  4. CNC Hot Wire Foam Cutters
    By HotwireCutter in forum Manufacturer News
    Last Post: 02-05-2012, 09:04 PM
  5. Software for foam cutter - any recommendations
    By rckeith in forum Machine Control Software
    Last Post: 08-08-2010, 10:14 AM
