Thread: in calculating the tool path
Well you just subtract the tool radius from the arc radius and add the tool radius to the line y co-ordinates before you do the pythagorus bit.
I've just been writing code to do much the same thing, decided pythagorus was a lot easier than applying the cosine rule even if it meant rotating the chord into the vertical and then back again :whistling:
Just to make it interesting I also spiral down into draft angles and hemispherical sections which is taxing my brain a bit but I'm getting there. Slowly. The G-Code is a bit whacky, I define the arc centre using I and J but the end co-ordinates are not necessarily on the same radius as the start. Dubiously G-code legal. I had to mod my mill driving code a bit before it would accept a spiral
27-07-2010 #2
Thanks irving, I worked out what I needed this morning on the drive in to work and I agree with you. I just got the sin and cos swapped over but that don't matter it just rotates it through 90 degrees.
It's good to have confirmation before I try and code it. I am using the free language called Processing, it runs on all platforms.
Do you think there would be any interest if I posted the final result? I am also working on a program to send a G code file to the miller. I wanted to use Replicator G but I can't get that to work reliably on my Mac, despite several email exchanges with the authors.
27-07-2010 #3
27-07-2010 #4
Thanks routercnc, that is in essence what the solution posted by irving actually is, only the equations have been bashed about already to give the solution. The only difference being that instead of using:-
The equation for a circle (x^2 + y^2 = r^2)
then you use the parametric equation for a circle of :-
x = r SIN(theta)
y = r COS(theta)
27-07-2010 #5
Well, my contribution to this thread will be about as much use as tits on a kipper.
Reading it has seriously damaged my belief that I will ever master the maths involved in rudimentary CNC :sad:. I am beginning to think I should have listened to my old teacher instead of getting stuck into some practical human biology!!
Panic stricken in darkest Dorset!!
Tim G-C
“I disapprove of what you say, but I will defend to the death your right to say it.”
(attrib. Voltaire but written by Evelyn Beatrice Hall "The Friends of Voltaire" 1906)
Calculating timing belt lengths
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 10-12-2015, 11:32 AM -
Romi EZ-Path S Lathe crt replacement
By Nemo1966 in forum MonitorsReplies: 5Last Post: 07-10-2013, 04:25 PM -
Calculating Stepper Motor Power? Strength?
By antsals in forum General DiscussionReplies: 2Last Post: 11-07-2011, 12:18 PM -
Calculating torque settings for bolts.
By swarf-boy in forum Machine DiscussionReplies: 2Last Post: 22-12-2010, 12:18 AM -
Calculating forces on linear bearings ...
By Jonathan in forum Rails, Guideways & BearingsReplies: 7Last Post: 24-11-2010, 02:26 AM
