  1. well £24 delivered isnt bad...
    blanking out 49 holes might not be as easy as you think, you might need to provide an alternate sensor. Also if you do blank the holes you'd prevent using it for closed loop speed control later...
    I liked the look of it, its fit for purpose and the price is not bad, although im not sure if i will end up buying another sensor, it will be interesting to see what that chip is on the back.
    As always im thinking you are correct, maybe ill just mount another sensor on the spindle and be done with that, mind you i couldnt find anything suitable on fleabay
    Rick
    This may sound stupid, but im just wiring up the drivers to the BOB and i was wondering if there were default ports used for axis, IE X=pin??? y=pin??? etc.. I do like to keep things default, as it makes things less complicated If I get problems.
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
