Page 13 of 35 FirstFirst ... 3111213141523 ... LastLast
  1. #121
    Phenolic :question:
  2. #122
    It's called Phynolitic don't know if i spelt it correct, I used to use it for engraving I have a small sheet of Black with White centre and larger sheet White with Black centre
    phill
    Hey thanks Phill, you would have thought it would be much more common wouldnt you, it looks like this is just the sort of forum it would get used and spoken alot.
    Im determined to find a supply of it, as i think it is something i know i will use in the future. the panel im designing is 16.5" x 7.5" but i suspect i will have to buy a bigger sheet so i will have to find some more projects to use it on:naughty:
    Again thanks Phill
    Rick
  3. #123
    Hey phill, shall I change it in your quote in My post as well??lol
  4. #124
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 13 Hours Ago Has a total post count of 301. Received thanks 28 times, giving thanks to others 13 times.
    Hey Rick,
    looked back in my records and found ref: to Pantograph supplies, changed name now but you will find all kinds of sheet here tell you now will be expensive.
    http://www.pantograph.co.uk/pdfs/materials.pdf
    Phill
  5. The Following User Says Thank You to phill05 For This Useful Post:
  6. #125
    Hey Rick,
    Phill
    Hey Phill, that is magic, to be honest its not much more than normal perspex, i will have a read through that and get some ordered monday, that will get another job out of the way, the next thing will be to sort out the engraving.
    Thanks Phill
    Rick
  7. #126
    Phenolic is the American name for Tufnol, it's not a two part material.
    John S -
  8. #127
    i2i's Avatar
    this place used to be local to me, and they just call it engraving laminates.
    http://www.westwardplastics.co.uk/s_abet.php
  9. #128
    Quote Originally Posted by i2i View Post
    Cheers i2i, Ill give them a call monday, see if they do smaller pieces..
  10. #129
    phill05's Avatar
    It was called Phenolic board a three part white-black-white and black-white-black 20 plus years ago and was purchased in the UK I still have small stock and paperwork for it.
    Phill
  11. #130
    The earliest form of the phenolic was bakelite,just an old material brought back to life with a new material added.
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
