Page 23 of 35 FirstFirst ... 13212223242533 ... LastLast
  1. #221
    i2i's Avatar
    on the x axis there is a gap at either end, but i'm not sure on the other axis.
  2. #222
    Quote Originally Posted by i2i View Post
    You're right they are used as home switches, and i suppose as long as the area is kept clean they would be ok for the job. .
    Well when its running i will do some tests and see just how accurate they really are.
    Do you have a schematic for the relay add on.
    Looking at the data sheet it looks like it will drive a small relay direct, or even switch an input to ground.
    Well its not really A wiring diagram but i think you will understand it:-
Name:	Proximity wiring.JPG
    Rick
  3. #223
    i2i's Avatar
    Rick
    I'm wondering if the BU wire could be used to directly take a mach input low, or keep it low until the gap appears. If you get chance give it a go.
  4. #224
    i2i's Avatar
    on a bit of a side note, i picked up a soft ended r8 arbour today to test out the auto changer.
  5. #225
    i2i's Avatar
    As soon as i get round to converting my 3hp boxford 240 tcl, i'll get onto turning it.
  6. #226
    I did consider this but i was looking at the boxford covered up in the garden pooring with rain and decided i wanted to do something and i just decided i had a 5 relay board and small 12v powersupply so i did it, it may be overkill but at least with the relay design i can utilise the sensors output without a PC fullfilling my manual control Obsession!!! lol
  7. #227
    i2i's Avatar
    lol
    lol:naughty:
  8. #228
    Im so gutted because i dont have an R8 taper, See below
ID:	2664 Click image for larger version.
    Ive no idea what that taper is :cry:
  9. #229
    i2i's Avatar
    have you pulled that out of another holder that's in your spindle, as it looks just like the colchester easy change holder from a 30 int holder. Or does that go straight into the spindle.
  10. #230
    i2i's Avatar
    there should be a cap head screw that goes through the centre of your easychange holder. Or does the spindle bolt screw into the top of the easy change
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
