Thread: The illusive Boxford 260vmc
21-08-2010 #261
I will try that now.
21-08-2010 #262Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
21-08-2010 #263
yes we can make the axis go the right way, but the movement is the important one for now
21-08-2010 #264
Ok if i move the Z axis from 0.0000 to 1.0000 i get a movement of 5mm.
21-08-2010 #265
ok change the steps to 200, and try again
21-08-2010 #266
Ok with 200 steps if i jog the Z axis from 0.0000 to 1.0000 i get a movement of 1mm. but slow.
21-08-2010 #267
it will be slower as it's a fifth the amount of steps, but it's the RIGHT AMOUNT OF STEPS PER UNIT.
This must stay at this setting.
Next step is to set the jog rate at 100%
Press "tab" to get the mpg screen and set the jog rate to 100% (just below the "slow jog rate")
21-08-2010 #268
Ok it was already at 100% :)
21-08-2010 #269
to speed up the axis you raise the velocity, but the faster you go the more chance you have of stallling the motor and loosing steps.
21-08-2010 #270
Ok thats cool what would you suggest for volocity and accell
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
