Thread: The illusive Boxford 260vmc
21-08-2010 #271
the only time you alter the steps is if you change the mode the stepper driver drives the motor, eg., half step 1/8 step ect.
But for now we'll use the settings the drives are on, which gives you 200 steps per unit.
PS. see post 243.
21-08-2010 #272
21-08-2010 #273
i normally use 1500 for velocity and 50 for acceleration
You can of course increase these settings, velocity gives you speed and acceleration defines how quickly you get to that speed. Too much acceleration and it'll stall so be gentle with the acceleration.
I've had the boxford running at 3000 on the velocity, which is 3m a minute, but you risk stalling the motor that way, that's why i stay at 1500.
21-08-2010 #274
you may want to lower the velocity a bit on the "z" as it's always a bit heavier on the stepper, 1000 or 1200 should be good.
Have a play around, don't worry about stalling a drive, at this stage you're not machining so best to find out the limits of the drives now.
21-08-2010 #275
The motors Sound good (they sound right) at 1500 and im not in any hurry for more speed.
21-08-2010 #276
don't feel too confident, you've got the spindle to come.
21-08-2010 #277
i've not used the stepper drivers you have, so i don't know their limits. The settings i've used are for Parker sd2/3 drivers.
21-08-2010 #278
21-08-2010 #279
buy yourself a cheap tacho (ebay £7 approx), or use the pulse to set the speed range to match mach correctly.
21-08-2010 #280
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
Done
