Page 28 of 35 FirstFirst ... 182627282930 ... LastLast
  1. #271
    i2i's Avatar
    the only time you alter the steps is if you change the mode the stepper driver drives the motor, eg., half step 1/8 step ect.
    But for now we'll use the settings the drives are on, which gives you 200 steps per unit.
    PS. see post 243.
  2. #272
    Quote Originally Posted by i2i View Post
    PS. see post 243.
    Done
  3. #273
    i2i's Avatar
    i normally use 1500 for velocity and 50 for acceleration
    You can of course increase these settings, velocity gives you speed and acceleration defines how quickly you get to that speed. Too much acceleration and it'll stall so be gentle with the acceleration.
    I've had the boxford running at 3000 on the velocity, which is 3m a minute, but you risk stalling the motor that way, that's why i stay at 1500.
  4. #274
    i2i's Avatar
    you may want to lower the velocity a bit on the "z" as it's always a bit heavier on the stepper, 1000 or 1200 should be good.
    Have a play around, don't worry about stalling a drive, at this stage you're not machining so best to find out the limits of the drives now.
  5. #275
    The motors Sound good (they sound right) at 1500 and im not in any hurry for more speed.
  6. #276
    i2i's Avatar
    don't feel too confident, you've got the spindle to come.
  7. #277
    i2i's Avatar
    i've not used the stepper drivers you have, so i don't know their limits. The settings i've used are for Parker sd2/3 drivers.
  8. #278
    Well the spindle works from mach at the moment ive set the low speed to 320 and the high speed to 2000 rpm.. great fun lol
  9. #279
    i2i's Avatar
    buy yourself a cheap tacho (ebay £7 approx), or use the pulse to set the speed range to match mach correctly.
  10. #280
    i2i's Avatar
    you should get at least 3200 rpm from that machine.
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
