Page 29 of 35 FirstFirst ... 192728293031 ... LastLast
  1. #281
    I wasnt sure what to set the speed to the spindle or the motor, it looks like 3-1 gearing on the belt or something like that. So i just set it to 2000..
    Besides which how would i tell what speed it was doing :lol:
  2. #282
    i2i's Avatar
    there is a cermet preset on the cncdoctor analogue board, which normally needs to be set around max.
  3. #283
    i2i's Avatar
  4. #284
    i2i's Avatar
    you may find it cheaper, or cheaper postage if you search.
    I have one and they work perfectly.
  5. #285
    Quote Originally Posted by i2i View Post
    :lol: as you know ive got a Tachulator coming at the end of the month so i can wait although i might just buy one of those as well, at that price im sure i can find pleanty of uses for it :whistling:
    ahh before i forget how do you reverse the axis direction?
  6. #286
    Ok found it, so I have steppers all done working calibrated, Spindle working, and axis direction sorted..Ive been playing with this Pokeys55 board, Now thats a cool piece of kit, all ive got to do is get that front control panel drilled and sorted and im away :)....Mind you there is a few little bits to do not to mention the cosmetic side and the flood coolant system i intend to fit :)
  7. #287
    i2i's Avatar
    sounds like you're almost there, have you done the home switches yet, and does it home correctly. If so then it's soft limits next.
  8. #288
    I had done it but it was untidy so as i speak im tidying it up, should only take 15 mins or so then as you say its soft limits, I believe that you can set things up so that the axis hit limits and back off to home...
  9. #289
    I'm terrible at spelling...but loosing an volocity ...
    Pity you didn't have a webcam setup,Rick?
  10. #290
    Quote Originally Posted by GeorgeD View Post
    No what you mean is your "NOT" bad at spelling because you noticed what "IS" bad spelling, as an offset i can hold my breath for over two minuits!!:rofl:
  1. The Boxford 260VMC as you probably never seen it before!
    By rnr107 in forum Boxford Vertical Mills
    Last Post: 28-04-2021, 07:57 AM
  2. Boxford 260 VMC
    By shoeswith in forum Boxford Vertical Mills
    Last Post: 10-04-2017, 06:20 PM
  3. boxford vmc 300
    By bigred5765 in forum Boxford Vertical Mills
    Last Post: 22-04-2014, 04:22 PM
  4. Boxford mt2
    By Hellfire in forum Boxford Lathes
    Last Post: 03-08-2012, 08:46 AM
  5. Boxford 160 TCL
    By Brinner in forum Boxford Lathes
    Last Post: 31-03-2012, 09:11 PM
