Thread: The illusive Boxford 260vmc
21-08-2010 #281
I wasnt sure what to set the speed to the spindle or the motor, it looks like 3-1 gearing on the belt or something like that. So i just set it to 2000..
Besides which how would i tell what speed it was doing :lol:Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
21-08-2010 #282
there is a cermet preset on the cncdoctor analogue board, which normally needs to be set around max.
21-08-2010 #283
here's the tacho.
http://cgi.ebay.co.uk/Digital-Laser-...t_Equipment_ET
21-08-2010 #284
you may find it cheaper, or cheaper postage if you search.
I have one and they work perfectly.
21-08-2010 #285Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
21-08-2010 #286
Ok found it, so I have steppers all done working calibrated, Spindle working, and axis direction sorted..Ive been playing with this Pokeys55 board, Now thats a cool piece of kit, all ive got to do is get that front control panel drilled and sorted and im away :)....Mind you there is a few little bits to do not to mention the cosmetic side and the flood coolant system i intend to fit :)
21-08-2010 #287
sounds like you're almost there, have you done the home switches yet, and does it home correctly. If so then it's soft limits next.
21-08-2010 #288
I had done it but it was untidy so as i speak im tidying it up, should only take 15 mins or so then as you say its soft limits, I believe that you can set things up so that the axis hit limits and back off to home...
21-08-2010 #289
I'm terrible at spelling...but loosing an volocity ...
Pity you didn't have a webcam setup,Rick?
21-08-2010 #290
There are currently 12 users browsing this thread. (0 members and 12 guests)
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
, as an offset i can hold my breath for over two minuits!!:rofl:
