Thread: The illusive Boxford 260vmc
24-08-2010 #311
25-08-2010 #312
25-08-2010 #313
makes it really easy to use mach, no more clearing an area to use the mouse, and it gives a good size display. Well worth the expense.
26-08-2010 #314
All our machines have touch screens on them, there is no place in a workshop for a mouse.
Look on Ebay for screens out of one armed bandits, very heavy duty, frame mounted and because they are not in fancy cases you can pick them up for £50 or so.
John S.John S -
29-08-2010 #315
John youve gone and done it now, Once ive finished the machine i will get a touch screen....
Oh while im here ive found a little circuit that im going to incorperate into the system so mach knows what the spindle is doing and i can output true rpm to the 4x20 lcd..
http://www.krupin.net/serendipity/in...achometer.html
20-10-2010 #316
Well Hi all im back on the project after 8 weeks working away. A quick recap will let you know the hardware side of the machine is completed to a stage where i can start using software, and having decided from the begining to use mach i was looking at the next steps. Having spent most of my time away from a conected machine this has been hard but for ease of use im leaning toward Vcarve.
There was an odd thing with the machine which i believe is configuration but im not sure. When i use jog or the shuttle the axis move at full speed, but when i use the mdi and just say type.. X 100 the axis just seems to jog really slowly any ideas??Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
20-10-2010 #317
press tab, and look at the slow jog rate. Set it to 100%
20-10-2010 #318
nice to see you back mate, who's "C2C"????
20-10-2010 #319
Hi i2i sorry abaout the C2C bit im still very tired lol. The slow jog rate is already at 100% i must confess im not sure what ive done to it lol
21-10-2010 #320
have you set the feed overide to a low setting
The Boxford 260VMC as you probably never seen it before!
By rnr107 in forum Boxford Vertical MillsReplies: 36Last Post: 28-04-2021, 07:57 AM -
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
